Rebuild a cbr400
- One Hit Wonder
Rebuild a cbr400
Hi I'll I recently perchased load of cbr 400 stuff I'm trying to rebuild a engine I'm at valve clearance at the mo and now stuck I have a pot of shimy things is there a default size for inlet and exhaust like a start point some shims have numbers on do thay mean anything becouse the don't measure up with metric or imp thank you for all help
Re: Rebuild a cbr400
Hello - apologies for the delay in approval!
Would suggest you look in the documents section http://www.400greybike.com/docs.htm
there is a range of clearances for both inlet and exhaust - would suggest you get a look at the manual, or a haynes - you really don't want to be getting it wrong.
The shims will be used according to the measurements taken so that you can get them into the tolerance.
You need - feeler gauges and a digital vernier
good luck :)
good luck :)
