Fuel tap vaccum pipe
britaxcooper
Hi All,
I've had my NC30 stood for the last 4 months due to other things happening. Anyway I've had problems trying to get it to start... to cut a long story short the fuel tap vaccum pipe has come off so its not opening the diaphram. I must have knocked it off removing the fairings.
As its dark and cold ive left it in bits for now, could someone tell me where the pipe goes to? So i can hunt for it.
Also is there only the one vaccum pipe?, whats the other "union" for?
Re: Fuel tap vaccum pipe
Yep - outside one is the vacuum and the middle one is a drain for the casing I would guess?
Jenksy
You could always do the modification to the fuel tap that does away with the vacuum pipe, it's pretty simple to do. There used to be instructions on here so if you have a search I'm sure you'll find how to do it, if you cab't find the info let me know and I'll scan and email the instructions to you.
viper_biker
- RVFHooligan
Viper, did you rotate your fuel tap cover so the vacuum line points forward instead of down? Mine points down as in britax's post. I am sure there is no functional difference.
- eltel
Hi, JenskyJenksy wrote:You could always do the modification to the fuel tap that does away with the vacuum pipe, it's pretty simple to do. There used to be instructions on here so if you have a search I'm sure you'll find how to do it, if you cab't find the info let me know and I'll scan and email the instructions to you.
I'am interested to know how to do this mod, any step by step guide available
Cheers,
Terry
If you can't get it up them, then get it down them.
viper_biker
Yup, I did exactly that. Makes no difference what way it faces, as long as it's not blocked it'll work fine.RVFHooligan wrote:Viper, did you rotate your fuel tap cover so the vacuum line points forward instead of down? Mine points down as in britax's post. I am sure there is no functional difference.
Jenksy
Hi Terry
Cut and paste link (don't know how to put a straight link on here yet, must learn) below. it tells you all you need to know and the benefits.
http://www.akhara.com/nc30/fueltapmod/index.html" onclick="window.open(this.href);return false;
It's pretty straight forward to do, even I managed without parental supervision.
- eltel
Thanks Jenksy,
I understand now. Will tackle this at the weekend.
Cheers,
Terry.
Cheers,
Terry.
wullvfr
- Bike owned: zx9r c1
viper_biker wrote:Yup, I did exactly that. Makes no difference what way it faces, as long as it's not blocked it'll work fine.RVFHooligan wrote:Viper, did you rotate your fuel tap cover so the vacuum line points forward instead of down? Mine points down as in britax's post. I am sure there is no functional difference.
fankfuk for that,had me thinking as mine is different also.....its always worked fine but i was wondering why it was different to the picture....
william
