Popping Out of Second gear
I know it's a common fault with NC29s.
What is the best fix for this - when I say "best" I mean "Most Cost Effective" :D
May I add I have the technical knowledge of an Amoeba.... :)
Re: Popping Out of Second gear
There is 2 ways...
Buy a new engine with a good gearbox.
Or engine out split the casings and fix the worn dogs causing the problem.
Personally I would go for the first option, either way you are taking the engine out.
