nc23 fork refubishment
gaz@nc23
hi everyone,
this is just a quick one, my front suspension doesn't really fill me with confidence in the corners, and they dive under braking of any kind
so my question is what would be the first port of call for improving the suspension?
i was thinking i should use a heavier grade oil, (maybe 15w) as i've read on here that the suspension is designed for small light japanesse folk, n at 12.5 stone, i think i may be to heavy. or would i be better getting some new springs like the hagon progressive fork springs. or even paying someone to refurbish them profesionaly.
i'm hoping someone on here is a suspension guru
please help so i can have some confidence
thanx gaz
thanx gaz
scratchin
Re: nc23 fork refubishment
i would personally get them uprated, i did mine myself and fitted ohlins internalls and the difference is unreal, its not that hard to do if your handy with the spaners, but it also depends how much you got to spend, a rebuild with fresh springs and oil is cheaper and if done by a susspension specialist who would set them up correctly to your weight would also make a huge difference, end of the day its all down to the cash you can afford
stimpy
yep,new springs,heavier oil,and the correct air gap...cant go wrong, ive raced mine like this for 3 years and its been very competitive
give graeme france a call for parts and specs
stimpy
stimpy
gaz@nc23
nice one guys,
im gonna go for the heavier oil and springs option, coz i aint got that much to spend,as much as i'd like some ohlins internals, but is there any particular band and or type of springs that u wud recomend? n wheres best to get them from?
scratchin
all the big named brands are reasonable price if your only buying springs, why not drop graeme france a line im sure he could advise as to whats best
stimpy
you dont need the name brand stuff in the 23 front end...it works well with just the spring and oil change...ive raced guys with even the 600 frontend conversion done...still kicked ass
stimpy
stimpy
little nick
GF will advise you on the springs (inc rate), oil & air gap. He will also be able to supply you the parts (good proce also).
If you decide to go else where - I suggest you do not go for progressive springs - you want linear, with a spring rate to suit you & your riding. Any proper spring supplier will be able to help.
However - GF is a one stop shop
gaz@nc23
hey guys thanks for the advise, has anybody got a contact number or email for graeme france? so i get this sorted as by all accounts he's the man.
cheers gaz
cheers gaz
scratchin
07778628448
- Sligeach
get the bits off GF and before you go at it have a look on youtube.
i have to confess that between this forum, youtube, haynes and years of messing in my Dads workshop i have got most of my bike maintenance from.
i like this youtube link
http://www.youtube.com/watch?v=KDY4sHEn ... annel_page" onclick="window.open(this.href);return false;
