Nc23 Forks
Nc23 Forks
Hi all,
I've got my NC23 forks stripped at the moment for new seals and fresh oil, and when they came apart i noticed that the Damper Rod Bolts are different lengths on each fork. Below are some pics of the stripped forks, apologies for the poor quality.
In the pics below you can see the two different length bolts:
One of the bolts measures 27mm, and the other measures 18mm. Surely they should be the same length? They appear to be the original bolts.
I'd be muchous gratious if anybody could shed a little light on this for me!
Cheers, Matt
Cheers, Matt
Re: Nc23 Forks
What is the problem - Damper Rod is tubular inside.... maybe bolt with other length will fit...
Re: Nc23 Forks
it wont matter,its only to hold the gizmo in...unless of course your really into balance,then u may want to do summin about it
whats proberly happened is the orig has been stripped getting it out...and thats the replacement
stimpy
stimpy
Re: Nc23 Forks
Cheers for the responses guys, just realised that the damper rod is tubular!!
Re: Nc23 Forks
unfortunatley matt has realised his head is tubular also.......LOL
