base gaskets
rrsp
Bike owned: fzr600-,yzf750-,owo1,750
base gaskets
Post by rrsp »
does any body know, if you can get different thickness base gaskets, like the yzf kit ones, or has anybody used 2 or more standard ones together on there motors. 3tj by the way ?
Taggyd
Bike owned: fzr 400 3tj x 2, cbr900rrs
Re: base gaskets
Post by Taggyd »
ive heard of people using two gaskets in the past though not specifically on an fzr!
Thunderbike_steve
Re: base gaskets
Post by Thunderbike_steve »
Try this link
http://cometic.com/custom.aspx
http://cometic.com/powersports.aspx
They can do a base gasket for the yzf whatever thickness you need. I'm about to order a 3.5mm one for the 727cc engine i'm building.
Only problem is the postage from America
Re: base gaskets
Post by Evilchicken0 »
Hey Steve ... is the thicker base gasket reusable ???
If not would it be better to get an alloy plate cnc cut and use 2 gaskets ... that would give you some rebuildability.
Otherwise - How about we buy a few between the interested parties (I'm in) and share the total costs ???
Thunderbike_steve
Re: base gaskets
Well evil my pistons should turn up tomorrow, though I wont be able to measure them until thurs as I have CCS tomorrow :( then a leaving do to go to. But as soon as i've measured i'll put a post up and order a few then.
They are made from copper, so are softer than ally but can take a higher temp. If the head is torqued up correctly i think you could use them again but measure them first ;) maybe add a normal base gasket if it has contracted slightly.
You seem well up for the 727 Boris, think they could be a monster, maybe as fast as a new 600.
Re: base gaskets
Definately up for the 720 ... I've got a 4JH in the garage as we speak. Do your pistons raise compression too ??? Let me know how much the gaskets are + postage
Did you get the pistons from TTS ??? I'll try and see them at the Excel Show and order them there.
On a similar subject ... I finally got a set of versize pistons for my SB6 1146cc and a bit of a raise in compression to 12.9 so a bit like you I've got bits of engine in different places of my flat.
