Indicator problem
rojer386
Indicator problem
Post by rojer386 »
When I'm using my indicators, my right signal flashes as normal but when wanting to signal left it doesn't work. If the bike is ticking over on the drive and I switch on the left hand indicator, nothing will happen for around a minute or so. After that it may work but not as it should.
Any ideas on why the right is working but not the left?
Brian
mrdidlydingo
Bike owned: NC29, 30, 35, RDLC, GSXR
Re: Indicator problem
Post by mrdidlydingo »
Check your indicator relay or module
Check your handlebar switch (most likely)
Check all connections
It will be something stoopid !!! had similar troubles with G/F bike turned out to be the switch innards were manky so worked fine when swapped, was easy for me as I had an NC30 hanging about at time to test different things
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
strip the switchgear down first and give it a wee clean,use some wd40 on the contacts......
if this does not work then check wiring etc
william
leopard_pagan
Bike owned: used to have a NC29
Post by leopard_pagan »
check the bulbs as well.... all 4 of them!
