NC30 caliper overhaul
Smoky
well, ive decided to spruce up the front end, and since im generally happy with the power and feel i get from the standard fronts theres no need for an upgrade- but i am going to attempt to overhaul the calipers and possibly the master cylinder-
im not bad with a set of spanners, and am no stranger to fiddly bits (2 years fixing a little aprilia rs125)
but what i want to know is: how hard is it? hard enough to warrent taking to my local garage?
cheers guys!
cheers guys!
viper_biker
Re: NC30 caliper overhaul
If you know the difference between a spanner and a screw-driver you'll be fine mate.
Smoky
lol fairy muff
was just a touch concerned as its not really good practice to mess around with important parts like that...
guess ill have a crack at it myself then.
cheers mate
cheers mate
viper_biker
Sure if you get into any difficulties let us know, we'll steer you in the right direction.
Smoky
diamond-
watch this space, soon to be updated with piccies!
wullvfr
- Bike owned: zx9r c1
definately worth doing yourself,save plenty cash and when you have done it once it will give you the confidence to do it again and again...........
the only downside will be bleeding the brakes after putting it all back together,it takes time and patience and bleeding at the m/c helps!!!!!
william
william
viper_biker
Or a syringe fron the bleed nipple (teehee) will do the trick.wullvfr wrote:bleeding at the m/c helps!!!!!
Smoky
that was my only concern-
ive bled brakes before, so i know the drill- but its always been the single caliper at the front-
is it a pig of a job to bleed the twin fronts on the NC30?
As wull said, once you done it once its easy. just make sure you got all the right tools before you start, vacume pumps come in handy as do piston removal tools
viper_biker
Get them off, split and cleaned first then worry about that later. It's not really that bad.Smoky wrote:that was my only concern-
