Handle bar grip changing
BillyBarcelona
Post by BillyBarcelona »
Hi folks, on with my CB400 SF resto (1992) and the handle bar grips need changing, I've seen utube clips about removing old ones on newer bikes that have bar ends but the 400 has what looks like a plastic cap on the end of the bar.
Do I need to do anything to the throttle cable before destroying the current rubbers please?
cbr400rrn
Bike owned: NC29 CBR600F
Re: Handle bar grip changing
Post by cbr400rrn »
I’ve never had a cb400 sorry so All i can suggest is take your time and assess how things are put together as you take it apart carefully
Foxy400
Regular Member
Post by Foxy400 »
I've changed grips many times and never had to do anything to the throttle cable before hand. I remember the first time I tried it I spent a long time trying to peel the grip off :stupid: then someone suggested cutting it off :roll: so it was out with the Stanley knife.
Swingarm
Bike owned: AR 125, NC30
Post by Swingarm »
If you have access to compressed air squirt some down under the rubber grip while you pull it away. Also works for putting them back on.
Or try WD40 but you'll have to do a good job cleaning that up. Brake cleaner also works as a temporary "lube" to slip new ones back on which will then evaporate. But make sure materials that will touch the cleaner are compatible.
Failing that, as Foxy says, cut the blighters off.
I can't imagine the throttle cable needs touching but could be wrong. Can you post pics?
BillyBarcelona
Thanks for the advice guys, I'll give it a go.
BillyBarcelona
Guys, I've now discovered that the bike had had heated grips fitted previously, I'm really cautious about damaging something from the original set up, do I just start stripping the old grips off and hope for the best?
Swingarm
Post by Swingarm »
Never had heated grips.
But it sounds like it's not very easy to remove them if you want to keep them.
https://www.advrider.com/f/threads/oxfo ... ll.604773/
MadMotoUK
Bike owned: FZR400,600, CBR893
Post by MadMotoUK »
Isopropryl alcohol squited down between the rubber and throttle sleeve/clip on will soften the glue allowing enough time to remove the grip intact.
