cb-1 400 tank and other parts needed
Posted: Mon Jan 05, 2009 9:41 pm
by ladybiker
anyone know of anywhere i can get hold of a cb1 petrol tank, regulator,plastics at decent prices?
Re: cb-1 400 tank and other parts needed
Posted: Tue Jan 06, 2009 5:34 pm
by Ensie 27
ladybiker wrote:anyone know of anywhere i can get hold of a cb1 petrol tank, regulator,plastics at decent prices?
Tanks are getting a bit tbhin on theground now, esp ones without dents. I can get parts from Japan but the tank would be expensive to post. What plastics are you after, I have a couple of tails. As for the reg/rec, go for one of the later "finned" type ones, the earlier ones are pants
They're fitted to various model Hondas, including the VFR750.I might have a spare one, will need to check.
Posted: Tue Jan 06, 2009 11:45 pm
by amorti
i have a tail in need of some repair and a mudguard that's usable but could use spraying. both (in the case of the tail, nominally) in black. based in portsmouth. i'm not too interested in the hassle of posting, but a couple of beck's gets them if you can pick up in portsmouth.
Posted: Thu Jan 08, 2009 7:47 pm
by ladybiker
cheers. i have a tail piece but some bits are broken some lugs are broke its the tank more than anythign and the regulator, my bike is terrible in the cold i have to charge it every night and im thinking its that i need to sort out, but today it was real bad took ages to start wouldnt tick over really lumpy at first but ok by the time i got to work but had same prob when i came out of work.
And a dent in the tank if it aint too bad. i have a hole in mine at top so when i fill right up it comes out of the hole.
Posted: Fri Jan 09, 2009 7:30 pm
by Ensie 27
ladybiker wrote:cheers. i have a tail piece but some bits are broken some lugs are broke its the tank more than anything and the regulator, my bike is terrible in the cold i have to charge it every night and im thinking its that i need to sort out, but today it was real bad took ages to start wouldnt tick over really lumpy at first but ok by the time i got to work but had same prob when i came out of work.
Is the hole meant to be there? Or is it a rust hole? If it's meant to be there you're breather might be blocked - someone else had tha same problem recently. If you need the bike to use, I can sell you the reg/rec of my spare bike and pick myself up another one from Japan.
Posted: Fri Jan 09, 2009 9:52 pm
by amorti
Sounds more like your battery is dead. Where are you, one of the forum members will always have a look.
Posted: Sun Jan 18, 2009 3:23 pm
by ladybiker
its had a new battery and the hole is a rust hole, i can still use the bike but have to chagre in on a trickle charger everynight but not always reliable, cant leave it parked n e where else but homew over nithg or i get stuck as not too good and bumping it.
Posted: Mon Jan 19, 2009 1:41 pm
by Ensie 27
