mc21 throtle on nc30 fitting?
Spike16
ok iv bought myself a complete mc21 throttle assemble incuding both cables and was wondering exactly what i need to do to fit it to my nc30
iv heard loads of different accounts on fitting it i am not sure about anything now
do i keep the 30's throttle cables?
do u use 2 throttle cables or just the one?
do i use the throttle tube from the mc in the nc's housing?
cheers spike
cheers spike
Re: mc21 throtle on nc30 fitting?
Dunno man - you have it in front of you
My thoughts would be just the tube..
Spike16
nah hasnt arrived yet, well good bargain too, wont be fitting it until iv machined myself some nice clip-ons in the college tech room, gona see how much weight i can loose fromt he control area, with new clip ons and drilling the yoke a bit
Isn't an mc21 a cbr250? If so it will be the same pull as an nc30, maybe more.
I would ditch the return cable (seriously now, if the throttle spring snapped and you expect this cable to return the throttle you're dreaming!) and use the standard pull cable. It will easily hook up to your new throttle tube.
Spike16
mc21 is a nsr250, which is a quicker action throttle to the standard,
tyga put one on one of their project bikes and only used the one throttle cable, and i have a feeling u have to use the nsr's cable because of the different turn throw
- Jon
If you are running with no return cable the original cable will be fine, the size of the drum on a single cable settup makes no difference.
It is only when you have a cable going both ways that the length diffence between the inners and outers is critical.
regards
jon
regards
jon
tanuki
If its anything like the NC29 the return cable will not be long enough and if you want to use one you will have to have one made, I use one on my 29 trackbike and its great, also have a proper HRC single cable 1/5th turn throttle on the RVF.
