1wg 1988 FZR400 carb query
adibtanah
I can't get bike to perform at high revs. It goes fine from low revs to about 10k then justs does not go any further from 4th gear onwards. the bike is not restricted, we dont have those limitations in South Africa. Have replaced manifold rubbers, air filter, fuel filter, plugs, oils etc. The bike is stock and has 48 000km on the dial. It starts perfectly in Winter without using the choke and does not smoke at all. Mechanically it is sound, but I think the carbs need attention. I stripped the carbs today and found that 2 diaphragms have tiny holes in them. The needles have signs of wear on them. The jets look fine. I have orded a carb kit from Factory Pro in the states with emulsion tubes.
- Mikuni 3EN 00 E8212 Carburetor (Markings on the carb)
1. I need to find out where can I get new diaphragms from???
2. The most important question what is the float height using a vernier caliper???
3. How do I remove the emulsion tubes
4. How many turns for the pilot air screws 2 1/2 or 3 1/2 turns out?
I would appreciate help on these 2 topics.
Your help will be much appreciated
Adi B
Adi B
Re: 1wg 1988 FZR400 carb query
Quickest way to test your carbs is to buy a secondhand set from e-bay or somebody on here. Carbs aren't expensive, expect to pay £20-30 plus postage.
Float heights are set with a u-tube and the carbs in place, but I think it's probably the holes in the diaprams causing your problem
You can get a manual for a 1wg model on the web ... I cant remember the links but somebody on here can probably give you that. You can also get a manual on disc from ebay.
Marb
- Thieving Pikey Twat
http://www.fzrmanuals.nl/FZR400/FZR400A ... manual.pdf" onclick="window.open(this.href);return false;
