1994 CB400SF - buying advice
I have been offered a 1994 Jap import CB400SF for £600. It's covered 16k miles, although the speedo is still in KPH.
It is also currently fitted with a 33bhp restrictor kit which I would want to remove.
All the obvious things look to be OK, however it is in need of a new seat and some TLC. Would I be buying a whole heap of trouble?
Thoughts, advice muchly welcomed!
S
S
Re: 1994 CB400SF - buying advice
If it's a clean original example, you've checked it over thoroughly and ridden it and all seems OK, then I wouldn't expect too much trouble from it; it's a Honda after all!
Bear in mind though that it's a 14 year old bike, so don't expect it to be trouble free!
I bought my '95 Version R last winter, and it was pretty much faultless once I'd fixed a couple of things.
If you haven't owned a Super Four before; they're great fun to ride, practical and cheap to run, and they're very reliable.
Make sure that the it doesn't jump out of second gear though.
Cheers big man. Just a bit nervey of heart ruling the old head! You know what it's like!
Not sure whether spending a bit more and trying to find a minter would be better? Anyone selling one?
S
S
- superfourben
Has it done a true 16,000 miles (as the clocks are in KMs make sure the odo reads miles and not KMs), seems very low for a 14 year old bike, just check it hasn't been round the clock once, The seat should be easy to reshape and recover, I got mine done recently for not too much money (a lot less than trying to buy a new seat!). Otherwise if it all run fine, rides fine and looks good then I can't see you having too many problems with it! Good luck and let us know how you get on. :D
Watcha
Where did you get your seat recovered? It's the sponge that has been hacked to death on mine.
Best
S
Best
S
I got mine recovered at a local car upholsterers. They mainly do work on classic cars, and even had a light aircraft in for re-upholstering, but that meant they had a massive range of materials on the shelf I could paw and decide on. I went for: raising seat by 1&1/2", basket weave with red trim and gel pad fitted. Total cost £90ish.
This was in Kings Lynn. PM me if you're near there and I'll tell you where exactly.
Thanks for your help. Will keep you posted, but the deal on the bike I was hoping to get has fallen through. The seller turned out to be a bit of a chump!
So if you know anyone selling a minter, let me know!
S
S
