NC23 Highbeam mod help needed
sh4d0w0lf
- Bike owned: VFR400R NC24, GPZ600R
Hi guys, was wondering if anyone has some instructions / parts list for the headlight highbeam mod?
all help is highly apreciated
many thanks and merry christmas
Adam.
Adam.
wullvfr
- Bike owned: zx9r c1
Re: NC23 Highbeam mod help needed
merry christmas mate.....
i would have thought your bike would have had a high beam relay fitted!!!!
it is usually a low beam relay that is not fitted and is usually needed for running uk spec bulbs,when you use your lights and you put the full beam on do you get a clicking noise?
if you do then this is the relay you hear clicking.
the reason jap imports already have a full beam relay is jap spec bulbs are 60/35 so the full beam wattage is the same as uk spec so they require a relay for full beam but because the low beam is only 35w then they do not need a low beam relay.
i would first double check that you definately do not have the full beam relay,just check for the clicking noise whilst putting full beam on
william
william
sh4d0w0lf
ah, you've got me there m8. that must be what i meant lol as i know theres something to be done to the headlights...
any help with that is highly apreciated :D
wullvfr
there was a thread on here somewhere with a guide to doing the low beam relay,i think it is quite universal....not bike specific.i will try and find it but i know someone will give good info on this.
william
william
wullvfr
http://www.400greybike.cc/newforum/view ... +relay+mod" onclick="window.open(this.href);return false;
on the first page there is a diagram for doing the mod,it is on the diagram for the nc30 but it should give you a good idea.
funnily enough the thread was started by myself
william
william
sh4d0w0lf
thanks wullvfr, will be looking into the mod at some point within the next few months :)
once again many thanks and merry christmas
wullvfr
no problem at all
merry christmas
william
merry christmas
william
