Page 1 of 2
deristricted CDI
Posted: Wed Dec 24, 2008 10:21 am
by drifterwannab
Hello all
Am i right thinking this is a deristicted CDI?
Re: deristricted CDI
Posted: Wed Dec 24, 2008 5:31 pm
by leopard_pagan
what bike would it be for?
Posted: Mon Dec 29, 2008 1:00 am
by stimpy
its for a nc23...gold label cdi means derestricted
rrj
stimpy
Posted: Mon Dec 29, 2008 8:06 pm
by LozVTR
Ive got a gold label CDI also...
is there anything else I need to do with the bike to ensure its fully powered?
Is the 112mph speed restriction taken out by the gold CDI or do I need to do other mods?
thanks
Loz
Posted: Mon Dec 29, 2008 8:37 pm
by sh4d0w0lf
the gold label cdi by itself means that the bike is de restricted! you will most likely find that ure bike is an NC23-RRJ whereas my bike has a blue cdi which means that it is restricted also meaning that my bike is an NC23-RRK, you'll be able to go faster than 112mph without mods whereas i need to mod my bike!
hope that helps
Adam.
Posted: Mon Dec 29, 2008 9:38 pm
by leopard_pagan
NC23-RR-J to 112mph de-restrict you need a gold label CDI pictured above.
NC23-RR-K to 112mph de-restrict you need the resistor mod
NC29-all models to 112mph de-restrict you need res mod...
all of the above can also be de-restricted by fitting a KPH to MPH manual speedo converter ONLY if your speedo face is still in KPH. this mod does not work with MPH faces.
the 3rd de-limiter mod for NC23-RR-K and all NC29s is to remove the half moon shaped disk from inside the speedo. this is not a mod for mechanical beginners!
Posted: Mon Dec 29, 2008 11:51 pm
by Cammo
leopard_pagan wrote:NC23-RR-J to 112mph de-restrict you need a gold label CDI pictured above.
4th way: Unscrew your speedo cable...
Posted: Tue Dec 30, 2008 12:22 am
by stimpy
no other mods needed for the nc23rrk when u run the gold label cdi.
none,zero,zip
plug it in and go
job done
thanks for comming
dont forget to tip the waiters on the way out
stimpy
Posted: Tue Dec 30, 2008 10:23 am
by leopard_pagan
spot on stimpy.. but not everyone can get their hands on one.. so there are a few other options to pick from.
Posted: Tue Dec 30, 2008 1:25 pm
by LozVTR
nice one....thanks all
especially stimpy, I think you answered that one very well.
