Vfr400 nc30 main jet setting
Posted: Wed Dec 24, 2008 1:54 am
by dinv4
Hi all ....
Pls let me know the setting of the main jet ( saiz ) for vfr400 nc30.For the best performance.thanx a lot.
Re: Vfr400 nc30 main jet setting
Posted: Wed Dec 24, 2008 2:01 am
by Jon
To get jetting spot on needs a dyno run.
THat said if you post up what mods are done to your bike there is enough peopel who have messed with these bikes a fair bit that somone will be able to give you a pretty good starting point.
regards
jon
Posted: Wed Dec 24, 2008 9:00 am
by MexicanGringo
If you really want to get into it yourself and set it right, get a lambda sensor and run it on each header, not really that expensive either
Posted: Wed Dec 24, 2008 3:45 pm
by wullvfr
it depends what model bike you have whether it is the r3k,r3l/n,or even uk model.
the k model runs 110f/110r jets
the l/n model runs 115f/118r jets
and uk models run 120f/122r jets
it also depends on what modifications you have on your bike,aftermarket exhaust etc.
but these are the standard sizes :D
william
Posted: Thu Dec 25, 2008 9:39 am
by royster81
very difficult question to answer this ,i have had the same jetting in two bikes with similar exhausts and they ride completely different,one pulls really well and strong the other runs out of puff at 11k changed the jetting and it runs all most as well as the other one now
you could get a base setting (which is what wullvfr has just given you) but you will probably have to tailor it to suit your bike and needs
what has been done to the bike out of interest ?
Posted: Sun Dec 28, 2008 2:21 am
by dinv4
Hi all ....
my bike is M model .... so can I used for uk models run 120f/122r jets ?????
Posted: Sun Dec 28, 2008 6:53 pm
by wullvfr
is yours a uk model?
m model should be uk so yours will and should have 120/122 main jets,if standard!!!!
william
