Carb Synch Question
- RVFHooligan
Carb Synch Question
Can someone please confirm the vacuum ports / take off points on the right side of the engine for carb synchronization? Is it the vacuum hose point for the fuel tap on the rear and the screw on the SIDE of the front cylinder behind the T-Stat housing? The left side is obvious on the "intake runners" and the Haynes manual doesn't show the exact locations. Thanks!
- Sligeach
Re: Carb Synch Question
http://www.400greybike.cc/newforum/view ... =24&t=5655" onclick="window.open(this.href);return false;
- RVFHooligan
Thank you. I did a search and couldn;t find it. I searched for "carb synch", "carb synchronization", "carb synch ports", etc and this thread didn't come up. I guess you call it "balancing" over there. I have the $20 Motion Pro Carb screwdriver so I'm good to go. Thank you Royster for the pics. Cheers!
- royster81
glad i could help any
