3EN1 Main Relay Clicking - Bike Won't Fire Up
BlueR32
Post by BlueR32 »
On a short ride the other day the bike just died on the road. Pulled over and when ignition turned on I get a rapid clicking from the main relay.
I found this video describing it exactly but no clues as to root cause or fix:
https://www.youtube.com/watch?v=UrC_IBfChcA
Battery is 100% charged and is holding charge. All lights work fine. Starter motor turns over fine but bike will not start. No fuel pump or exup sounds either. If I disconnect the relay the exup does cycle.
I replaced the main relay with a new one but sadly that did not fix anything. Same rapid clicking.
Any ideas are most welcome!
MadMotoUK
Bike owned: FZR400,600, CBR893
Re: 3EN1 Main Relay Clicking - Bike Won't Fire Up
Post by MadMotoUK »
I would venture a guess that it's a bad earth or a bad connection on the starter switch, the relay base or a joint in the loom. Either way, the relay is not getting a constant trigger signal but rather a pulsed one.
BlueR32
Post by BlueR32 »
Problem solved! It was the connection to the fuel pump. Once I cleaned up the terminals inside the snap connector all was good again.
cbr400rrn
Bike owned: NC29 CBR600F
Post by cbr400rrn »
Thank you for responding with your findings and your solution to the problem. It will hopefully help someone else in the future 👍
Brandon88
Bike owned: ‘90 FZR400
Post by Brandon88 »
Thanks mate, literally have the same problem.
