VFR400 making a NC21 engine work in a NC24
Hi, i have a vfr400K with a blown engine.
It has a nc24 engine with a wrecked conrod big end bearing.
I cant find any listed nc24 engines for sale but can find nc21 engines (though they could be mislabelled as they appear to be missing the camshaft position sensor)
I know the nc21 has a camshaft sensor and some different plugs on the engine connectors. Does anyone know what would be required to do make it work with a nc24 loom and cdi. I could potentially swap some timing components from my wrecked engine to try and make them compatible
Re: VFR400 making a NC21 engine work in a NC24
Hello - welcome
You will find the answer on here, I'm sure - have a look in the search and keep your eyes peeled for posts by a member Neosophist - he has all of the knowledge in this area I would say
I thought a 400K was an NC21 and if yours has a 24 motor already, then it proves it can be done.
I'm familiar with Neosophist posts. They helped me a lot when i first got the bike in bits a couple years back
Its a bit of a weird bike, as best I can tell it came from the factory with the NC24 engine as there is a parts fiche that I have found for a 400k (https://www.bike-parts-honda.com/honda- ... me/2/32494 for anyone interested).
The carbs also measure 32mm and has the velocity stacks which matches with NC24 carbs as far as I can tell from posts and part fiches.
Mine is a vfr400k(j) 1988 but it at least shows some K models came with the 24 engine loom and cdi. It also matches some other quirks my bike has like 30mm front pistons.
Some posts make mention of NC21 engines having no front camshaft sensor, does anyone know if those bikes also came with the later 2 brown plug cdi from OKI or the 3 plug with red connector cdi's
