Puddle of coolant
Posted: Sat Jul 24, 2021 7:11 pm
So took the NC35 for a spin today. Lovely warm day (again).
Gets home, and and puts her away. 5 mins later, came back out to her. Puddle of coolant at the sidestand..... and i think i could hear the expansion tank water bubbling
So, moved her back a bit onto a dry bit in the garage. leaves her to cool down. Goes shopping....
Comes back, opens up the top radiator. Full of coolant. Opens the expansion bottle. Half full. No new puddles.
When i got her MOTd, i had to remove the top radiator to get brazed/welded, as it had been dripping coolant over the winter. But never drained the 'bottom half '. Put the radiator back on, and topped up. This hasnt happened before this year. Checked the manual, apparently theres a seal setup at the water pump where seals go to stop water and oil mixing and theres a hole to exacuate liquid. Nothin obvious there. And the system is still full.
I can only surmise it was the expansion overflow causing the puddle with her having been out on a hot day. I can only assume theres no airlock perhaps as the temperature guage never went above 1/2. and squeezing the hoses squidges the water...... Still strange tho...
Anyone got any good ideas or concur with my assessment? Cheers
