NC31 Starter Engine Stop Switch Wiring
drrkdrrk
Bike owned: 1992 Honda CB400 Super Four
Post by drrkdrrk »
Hello,
I have a 1992 CB400 Super Four NC31 with a hacked up harness and wondering if someone can help me identify this wire.
Coming from the hand controls, down to the connector side there is a brown/white wire that ends in a double bullet connector paired with a brown wire.
The brown wire has been cut and is just hanging there.
Photo of said connector here: https://1drv.ms/u/s!Al4_KW_YczvngeQLnqn ... w?e=m21pih
Also image of related wiring diagram, but it's low res so I can't make out if some of these wires are black, blue or brown and what they're connecting to.
https://1drv.ms/u/s!Al4_KW_YczvngeQNUr2 ... Q?e=w4MwS3
Appreciate any assistance.
Thanks!
MadMotoUK
Bike owned: FZR400,600, CBR893
Re: NC31 Starter Engine Stop Switch Wiring
Post by MadMotoUK »
Normally on Honda wiring the brown/white is used for the supply to any running lights from the main switch, such as dash lights and front sidelights. The brown wire feeding from the brown/white @ the switch end is the feed to the tail light unit for your rear lights (running light, not brake light). I would imagine, assuming you have working rear lights, that this particular cable has become redundant and the lights are being supplied from elsewhere due to a previous fault.
Bike owned: VFR400
Post by magg »
Info I have is for CB400F but may be a guide. If a Brown/White wire comes out of right side handle bar switch it may be related to the start function that disables the headlight during start up. There could be a Brown/white wire out of the left side handle bar switch to match.
