Electrical problem
This section contains all the FAQ's and our terms and conditions. Please take a few moments to read and get familiar with our policies.
You can report any issues or site based problems you have in this section too.
robertRVF
Bike owned: RVF, NSR, NS400R, RZV500R, Mit
Electrical problem
Post by robertRVF »
I opened the clutch cover to check the pickups and found on my RVF only one pickup and it looks correct? Does the RVF only have one pickup? I can get the spark to work and have tested all components and they work but still no spark? any suggestions.
robertRVF
Re: Electrical problem
Post by robertRVF »
Solved all the electrical problems and now working on performance improvements. Hoping to re-jet and get carbs set up. What sort of HP is a reasonable figure for an RVF with airbox?
cbr400rrn
Bike owned: NC29 CBR600F
Post by cbr400rrn »
What did you find with regard to having no spark?
Can't help with the potential hp figure though sorry
[quote=robertRVF post_id=392736 time=1630944054 user_id=13619]
[/quote]
They were supposed to be 53 out of the box - and as a standard bike, at sea level you might expect a bit more.
As you are up in the plains - you'll be looking at mid 50s
My experience tells me - keep the airbox and all flaps adn shizzle in there - a well fuelled bike that has no hesitations or flatspots is better than one that surges and gurgles to a peak.
Get in onto a Dyno -get a look at the ari/fuel graph and see what's what
robertRVF
Post by robertRVF »
I am looking to find the HRC recommended jet size for teh carbs. #148 front and #152 rear. where can i buy them? does anyone know? Bike is running lean at top end and producing already about 68Hp on the rear wheel. Would like to get that a bit higher. If i can rejet i am sure i will improve a bit.
robertRVF
Post by robertRVF »
BTW found the spark problem to be when the previous owner took the clutch off without the correct tool and jammed a spanner in between the clutch basket and starter clutch to get it lose. This dented a starter pick up point and caused the bike not to fire on the rear cylinders. New starter clutch and solved the problem.
[quote=robertRVF post_id=392740 time=1631013553 user_id=13619]
[/quote]
You can get them from most shops - Kehin jets.. They aren't specific to the NC35
Have you gone the whole hog then with no airbox and a ram air solution? Loads of us on here have been into trying to get the power - the search function might help you a bit too.
for some more inspiration - have you read the mngforce website for added ways to rinse money?
http://mngforce.typepad.com/
