Running on 3.
Foxy400
Regular Member
Running on 3.
Post by Foxy400 »
Got the NC35 out this morning after more than a month of enforced idleness. It started after a couple of attempts but was running rough. Without the choke it struggled but after a few more minutes it idled, although still didn't sound right.
I checked the headers and the pipe from cylinder 2 (front left) was barely warm, obviously it was running on 3.
So how do I proceed from here? What do I check first (and second etc)?
cbr400rrn
Bike owned: NC29 CBR600F
Re: Running on 3.
Post by cbr400rrn »
Easiest options first, is the plug lead on that cylinder, is there a spark from the lead when you crank it over, is the spark plug ok.
Bike owned: VFR400
Re: Running on 3.
Post by magg »
Fresh fuel and drain carbies. If no improvement remove carbies and clean.
Foxy400
Regular Member
Re: Running on 3.
Post by Foxy400 »
Ok thanks, a few things I can check before I call in the professionals.
cbr400rrn
Re: Running on 3.
Post by cbr400rrn »
Is this the one Graeme had? If so then as magg said drain the fuel and use new stuff
Re: Running on 3.
swap the plugs over too - get that one out and clean it.
It'll be reet
Foxy400
Regular Member
Re: Running on 3.
Post by Foxy400 »
cbr400rrn wrote: Tue Feb 16, 2021 9:48 pm Is this the one Graeme had? If so then as magg said drain the fuel and use new stuff
Sure is. Yep, I need to get it sorted. If I didn't have the NC29 (and the Bonneville) to play with I'd have been on it by now. Thanks for the suggestions.
Foxy400
Regular Member
Re: Running on 3.
Post by Foxy400 »
Finally got round to this job. The Haynes tells me to remove the right hand side panel to access the plugs. All well and good except my bike is currently wearing the Tyga bodywork. The side panels and headlight section are all one-piece. That means mirrors and air ducts off, indicators disconnected and the whole front manoeuvered forwards, lifting it out of the lower section at the same time. It's a real pain..and getting it back together is worse. So guess what..I'm putting it off until the weekend :roll:
richyrd5
Regular Member
Re: Running on 3.
Post by richyrd5 »
I wouldn't bother with the plug foxy(although I know these are finicky with them)I'd be more inclined to think it would be carb related as it's been standing...I'd take tank and airbox lid off and spray a bit of carb cleaner in the front jets/mouth of carb and tap the float bowl incase it's the float valve sticking...other 3 plugs are fine so doubt 1 would just go(although possible)..but I'd say carb is the problem..good luck
Foxy400
Regular Member
Re: Running on 3.
Post by Foxy400 »
Cheers Richy. Still haven't done anything yet. Feeble I know. Tempted to let Graeme France sort it..hey, it's only money :grin:
