Suipporting the front of an NC35
electronf
One Hit Wonder
Post by electronf »
Hi,
I have searched 15 ways to sundown but I cannot for the life of me find an answer to this question.
I have an NC35 with a pin type under the toke front stand and a normal single sided wingarm rear paddock stand.
If I want to remove the rear hub I could support the bike via stands under the pegs No problems there.
If, however, I want to remove the steering stem and bottom triple clamp obviously I will need to support the bike without using the front stand. Friends and fellow riders of other bikes have said just support it with s jack or the like under the sump. But I cant see any way to support it from underneath without removing the exhaust.
Does anyone have some sort of antigravity or levitation device I can borrow?
Foxy400
Regular Member
Re: Suipporting the front of an NC35
Post by Foxy400 »
I'm surprised no-one has come back to you with an answer. I've never had to do the job you're talking about but I reckon you have two choices. As you say, the exhaust needs to come off to get a jack under the sump. However if you happen to be working in a garage with reasonably strong cross beams, you can suspend the front end from there. Remove the tank and use straps (or rope) under the frame rails. I've seen it done. If you've not got a handy cross beam then it looks like the exhaust-off method is your only choice.
payneo
Bike owned: Vfr 400
Post by payneo »
Make a wooden block to go around the exhaust
payneo
Bike owned: Vfr 400
Post by payneo »
Sorry I was talking about an Nc 30
MadMotoUK
Bike owned: FZR400,600, CBR893
Post by MadMotoUK »
Same advice will extend to the NC30, they're not that much different :)
pack the gap between exhaust and sump - and then support on the front pipes - they are plenty sturdy
cbr400rrn
Bike owned: NC29 CBR600F
Post by cbr400rrn »
Abba stand and front lift arm. You can pick them up on eBay second hand and then buy the fitting kit new if this cannot be found on the above auction site. Picked my last one up for not much money.
No more worries about damaging the exhausts anymore
MadMotoUK
Post by MadMotoUK »
Good shout. I never even thought about an ABBA stand.
cbr400rrn
Post by cbr400rrn »
Sometimes I amaze myself :lol:
Suzuki416
Post by Suzuki416 »
Abba Skylift - its just amazing....
