NC31 Carb repair / rebuild
Posted: Mon Jan 18, 2021 5:21 pm
Hi Folks,
We have a CB400 SuperFour ( NC31) that has been sat for a bit too long and unsuprisingly, it now refuses to start. Prior to this it has been getting progressively worse at starting and has always ( for the 8 years we've been married ( wife not bike)) been a bit reluctant to sit at tickover until warm. I reckon it needs a decent thrash to clear its lungs but I can't do that until i get it running / MOT'd. Last time I had it running it took ages to come through on all four cylinders but once running it was fine. That was summer last year.
It's a 1993 K plate Jap import and has done about 30k miles, decent condition and no other issues.
It tries to start, clutch plates aren't stuck ... when it tries it'll huff and chuff and occasionally give a monumental backfire, sometimes with flame so it's clearly getting some fuel through. However it never quite catches enough to start.
Things checked .....
1. Fuel coming through fuel tap.
2. Drained some fuel out and run in the mower - starts and runs fine.
3. Opened the carb drains and fuel comes out.
4. Spark is good - but will remove tank and check plugs this weekend.
5. Battery was flat but good spare used - problem not fixed.
6. Nothing nesting in the airbox
7. CDI all looks neat and no frayed wires.
Which leads me to suspect what is in the tank and is now probably gumming up the carbs ....
Where are you getting your rebuild kits from - are those cheapo eBay kits ok for the gaskets / seals / carb to airbox rubbers? And what are these like to work on?
Part of me says just drop it to my local bike place and let them fix it but the other part of me knows that we're due another boring summer of no holidays so something to tinker with might be interesting.
Anyway interested to hear any thoughts.
