Coolant change, reuse washers ?
Kenthammer
Bike owned: 92 NC30 & 94 CBR900RRR
Post by Kenthammer »
About to change the coolant on the NC30, just seen the price of the 3 drain bolt washers, nearly spat my beer out.
What’s the view on reusing the existing washers?
I am assuming they are crush washers, any alternatives ?
richyrd5
Regular Member
Re: Coolant change, reuse washers ?
Post by richyrd5 »
If there copper just anneal them(get them cherry red hot and drop into cold water).'but they should be fine as is bud
cbr400rrn
Bike owned: NC29 CBR600F
Post by cbr400rrn »
Are they the ones at £3.88 each? Can you not take the old ones to a local motorfactor and see if they can match them? Worth a try.
it is of course best practice to change it but you can probably reuse it without issue, i have many times just reuse and make sure it didnt leak after getting upto temperature,
Kenthammer
Thanks guys, no they are not copper, probably steel.
£6.20 for a 6mm washer x 3, is really taking the proverbial.
Ended up reusing, as did buy them last time out and can’t believe I paid that much.
Half way through the job remembered I had promised myself not to take the front cylinder drain bolts out ever again out as they are a PITA to get back in with normal sized fingers, too late to remember so had to remove bottom rad to get access which has the added advantage of getting another 1/4 litre out of that rad, and just a thimble full out of the cylinder drain bolts.
All in all, got 2 litres out so nearly all of it.
Foxy400
Regular Member
Post by Foxy400 »
Kenthammer wrote: Sun May 24, 2020 9:57 am Thanks guys, no they are not copper, probably steel.
Every cloud has a silver lining :lol:
