NC30 Fork strip
- Bike owned: Honda SP1, BSA Golden Flash, H
NC30 Fork strip
Looking for advice, started stripping the forks on my NC30,now at the stage where i need to remove the bottom damper rod bolt, 6mm Snap on allen key socket, 12" breaker bar and all thats happening is i can feel the allen key beginning to twist, i ckecked the torque setting in the manual and it states 20nm, has this thing grown into the alloy? any tips as to best way to undo it?
- Bike owned: VFR400
Re: NC30 Fork strip
It screws into the damper tube inside the fork tube. Quite often the damper tube rotates with the bolt. An impact gun usually proves successful or a bar inserted into the fork tube that locks onto the damper tube can be used to stop it rotating.
Re: NC30 Fork strip
Thanks for that, I managed to get one out but the other one rounded out, I managed to drill that one out so all is good, just need to send the stantions off for rechroming,
Thanks for your advice
