NC30 uk bike ??
niccollotto
NC30 uk bike ??
Post by niccollotto »
hi guys and gals
its been a loooong time since ive been on here, but ive finally dragged it from the back of the garage and the re-furb is under way as sadly its gotta be sold :-(
question is, ive never been sure if its a UK bike, it has the oil cooler but earlier MOT'S show km's not miles
is it possible to tell from the details on the plate on the frame ??
appreciate any wisdom you have !!
cheers
Nick
richyrd5
Regular Member
Re: NC30 uk bike ??
Post by richyrd5 »
Hi,if it's got a plate on the frame and the frame number starts 200***** ,then it's a UK frame at least...does the engine number start at 200*****??..if so it's a UK model to...it is possible to drill the casings and retro fit the oil cooler,but needs engine completely stripped to fit a different oil pump etc...carbs are round metal slides like nc24/hrc type..big fireblade type indicators...relocated regulator on a different subframe...already has a highbeam relay fitted...etc..hope that helps
niccollotto
Re: NC30 uk bike ??
many thanks !
