Help with nc29 engine refresh
Asimarkus
Bike owned: NC30RK, NC35RR, NC29
Post by Asimarkus »
Hi guys, so I decided to rebuild my nc29´s engine as it has 110.000KMs... thing is that one of the conrods has a rare color and would like to replace it, I have more engine spares but the workshop manual says that con rods should go with shame weigh code, could I replace a con rod with a different weigh code? The actual ones have C code and I have others with A and B
mechannibalism
Re: Help with nc29 engine refresh
Post by mechannibalism »
NO! they must all weigh the same, you could get a performance shop to check them over and balance/blue print them.
Bike owned: VFR400
Post by magg »
Not sure if NC29 specs are the same as NC30 but for the NC30 there are a number of options for matching rods to the crank and the rods weights are not necessarily all the same on one crank. I have an NC30 crank with three A and one B weigh rods.
sa.racing
Bike owned: NC29 Race
Post by sa.racing »
Why is it a rare colour? from memory (although it has been a while I'll admit) there are 3 sizes and all are still available from Honda, Have you tried Graeme France? he stocks most of the hard to find parts for these bikes, where are you located?
Also have you measured the oil clearance on the cam journals? they tend to wear out and oval quite easily on these engines and at that mileage that would be the first thing I would check otherwise you could end up spending a fortune refreshing the rest only to find you need to source a new head!
just a heads up (no pun intended ;) ) if you have checked them already then ignore the last bit
Si
Foxy400
Regular Member
Post by Foxy400 »
I agree with the advice to contact Graeme France. He worked on my NC29 and transformed it. I couldn't believe the difference. He's currently got my NC35. I'd give him a call if I was you, although wait another week or so because he's out of the country at the moment.
