Fork upgrade on 1989 gsxr400
warro46
One Hit Wonder
Post by warro46 »
I've 1989 gk73a my question is can i put later year model front end, if I had a complete forks and yokes off say 1992 would it fit, and is there a noticeable difference. Thanks
mechannibalism
Re: Fork upgrade on 1989 gsxr400
Post by mechannibalism »
There is no just bolt in and knock your socks off swap. You can buy a$180USD "emulator" that's barely noticeable or if you want to stay with RSU forks It's possible (will require machine work) to bolt in a set of '03-'04 R6 forks (43mm) They have low speed rebound damping & high speed compression damping and a mid speed damping and are probably the best RSU forks and the best bang for the buck.......or you can do what I did here> https://www.instagram.com/mechannibalism
mechannibalism
If you are set on using newer USD forks, one problem you will run into (the RG/RD500 guys have seen a lot of this) is the larger tubes and larger triples interfere with everything in the front cowling, usually the frame is now too small.
moforockband
Bike owned: GK73a SP CRM250 mk3
Post by moforockband »
I made a good performance gain on my GK73 SP forks by using some ktech fork springs, and new 10wt oil on std dampers.
The forks now aren't the weak part in the chain anymore.
But the sp forks are fully adjustable, you may have the std ones?
Maelstrom
Bike owned: MC22, 3TJ1
Post by Maelstrom »
Here is an article I wrote about changing front ends. Might be useful. https://2fiftycc.com/index.php?threads/ ... orks.3046/
https://litetek.co
