Nc30 side stand
batchelor
Nc30 side stand
I’ve just fitted the rubber to the side stand as it was missing. I have a couple of questions
1 which way does it fit into the stand
2 which way does it bend when bike is on side stand (forwards or backwards)
richyrd5
Re: Nc30 side stand
I think it points forward as it's meant to catch if left down??so would then flip up...
- NGneer
Re: Nc30 side stand
Batchelor: There is an arrow on the rubber which wants to be on the outside face (when the stand is down) and the angle of the bottom of the rubber will naturally make the rubber bend BACKWARDS when you put the stand down. It is true this was due there being no side stand cut out Switch on the NC30 and the rubber foot was there (in theory) to flick the side stand up if you left it down, before it dug into the deck and spat you off.batchelor wrote: Sun Oct 06, 2019 7:59 pm I’ve just fitted the rubber to the side stand as it was missing. I have a couple of questions
batchelor
Re: Nc30 side stand
NGneer wrote: Thu Oct 17, 2019 9:22 amBatchelor: There is an arrow on the rubber which wants to be on the outside face (when the stand is down) and the angle of the bottom of the rubber will naturally make the rubber bend BACKWARDS when you put the stand down. It is true this was due there being no side stand cut out Switch on the NC30 and the rubber foot was there (in theory) to flick the side stand up if you left it down, before it dug into the deck and spat you off.batchelor wrote: Sun Oct 06, 2019 7:59 pm I’ve just fitted the rubber to the side stand as it was missing. I have a couple of questions
2 which way does it bend when bike is on side stand (forwards or backwards)![]()
Cheers for the information and pics. That’s a very clean bike.
- NGneer
Re: Nc30 side stand
No problem, and thanks.batchelor wrote: Thu Oct 17, 2019 12:43 pm Cheers for the information and pics. That’s a very clean bike.
It ended up as my Honda Britain but was just the only one I had with a clear picture of the side stand rubber fitted
Build thread here if you are bored
batchelor
Re: Nc30 side stand
That killed some time on a night shift. Nice speedo!NGneer wrote: Sat Oct 19, 2019 10:34 amNo problem, and thanks.batchelor wrote: Thu Oct 17, 2019 12:43 pm Cheers for the information and pics. That’s a very clean bike.
It ended up as my Honda Britain but was just the only one I had with a clear picture of the side stand rubber fitted![]()
Build thread here if you are bored, viewtopic.php?f=62&t=54015
