Front sprocket play
Lewis34
Front sprocket play
Hi lads,
Quick question.. is it usual to have slight play in the front sprocket or should it be completely solid?
Thanks,
Lewis
Thanks,
Lewis
- Bike owned: VFR400
Re: Front sprocket play
If talking NC30/35 then sprocket is solidly locked onto the shaft with a large nut.
- RickOliver
Sorry, but you`re wrong, Magg - the large washer is clamped firmly to the end of the shaft by the centre bolt but the sprocket behind it has a bit of lateral float.
This is done deliberately - if the bolt/washer clamped tightly on to the sprocket then the slight clockwise/anticlockwise movement of the sprocket allowed by the clearance in the splines as you accelerate and decelerate would slowly loosen the bolt....
Rick
Rick
JAFO
Speaking of front sprocket play I have a few other quick questions if I may add to the thread as I am about to replace both front and rear
On the rear sprocket, do you have to remove the hub to replace it or can you just unbolt the current sprocket it from the hub?
Also, what size is the bolt head for the front sprocket? Is it RH or LH threaded?
Thanks in advance
Thanks in advance
- RickOliver
No need to remove the sprocket carrier from the axle, just unbolt the sprocket from the carrier, front sprocket bolt is right hand thread.
If you are fitting a standard width (525) rear sprocket, be aware that the offset should be inwards, not outwards (i.e. fit it with the recessed side of the sprocket facing the carrier).
Rick
Rick
Rick, happy to be corrected but my aftermarket front sprockets have no lateral movement. The sprocket spline boss needs "crushing" to butt the bolt to the end of the shaft, but not much, perhaps 0.1mm. Torquing the bolt eliminates the 0.1mm. Maybe the OEM sprocket has a narrow spline boss. Don't have an OEM sprocket to measure.
