GK73A Brakes
go4ablast
- One Hit Wonder
GK73A Brakes
Afternoon All,
I've just purchased a GK73A and it runs quite well but the front brakes are very weak. It has braded hoses and the pads look ok.
How can the front brakes be upgraded on this bike?
Many Thanks,
Jake
Many Thanks,
Jake
mechannibalism
Re: GK73A Brakes
"weak" brakes sounds like a worn out master cylinder but check the pads and rotors for contamination. You are aware that some pads (HH) have to warm up to work so the first time you use them they would be weak. Get them working before you consider an upgrade...they should be more than adequate.
moforockband
Re: GK73A Brakes
Post a picture of the calipers you have. The 4 piston Tokico's are excellent even by todays standards.
An upgrade is the import Bandit 400 Tokico's which have 2 different size of pistons. Put some good discs and HH pads/lines/fluid and you'll throw yourself over the bars then.
