Starter Motor
Travis
Starter Motor
Post by Travis »
Hello,
I trust everyone is well.
Is the RVF 400 NC35 starter motor, the same as the VFR NC30's?
The starter motor on my NC35 has stopped working, and before I source one I need to try confirm if a VFR one will fit?
Thanks!
Bike owned: VFR400
Re: Starter Motor
Post by magg »
NC30 and NC35 are effectively the same part number.
Travis
Re: Starter Motor
Post by Travis »
thank you, i think i will much easier find a vfr starter second hand, than one for a rvf which is alot more rare here. thanks again.
Bike owned: VFR400
Re: Starter Motor
Post by magg »
Maybe the starter solenoid has failed. If it is the motor, it may only need brushes.
Travis
Re: Starter Motor
Post by Travis »
i see that Wemoto sells rebuild kits for the starter, Im tempted, but the cost is high to import, its alot more affordable to get a second hand starter. but then I may wel just have that one fail, so im torn at the moment on how to proceed.
Bike owned: VFR400
Re: Starter Motor
Post by magg »
Is this starter solenoid functioning correctly.
Travis
Re: Starter Motor
Post by Travis »
magg wrote: Tue Mar 19, 2019 9:22 pm Is this starter solenoid functioning correctly.
yes, its brand new. i put power direct to starter motor, nothing. solenoid clicks, I can hear it working. :(
Bike owned: VFR400
Re: Starter Motor
Post by magg »
Have you removed and disassembled the motor, cannot offer any repair advice without inspection.
Travis
Re: Starter Motor
Post by Travis »
magg wrote: Wed Mar 27, 2019 11:28 am Have you removed and disassembled the motor, cannot offer any repair advice without inspection.
no not yet, i actually havent got the bike in the workshop yet, its in the que. its good to know that its serviceable though, and once stripped and removed i will come back with some images. thank you
