Need help, Put a hole in cam holder where it holds the bolt to the rocker cover
ebroon
Hey guys, i was drilling the cam holder to install a helicoil but i drilled it on a angle and off center and ended up making a hole in the holder.
I was wondering if i can tape the hole and fill it with jb weld and tap it (this time ill get someone that knows what theyre doing) or do i need a new holder set
Thank you
https://imgur.com/a/y8nVbkZ
Thank you
Re: Need help, Put a hole in cam holder where it holds the bolt to the rocker cover
Welcome - I'd buy a new cam holder :)
chekc the sales section, dGeoff33 (or whatever he calls his august self these days) will almost certainly sell you one...
ebroon
Thanks for the replyCMSMJ1 wrote: Fri Feb 01, 2019 10:16 am Welcome - I'd buy a new cam holder :)
