what's the part number?
ligurt
Post by ligurt »
What's the part number of a Magtek front wheel bearing?
Re: what's the part number?
Have a look on the fiche?
ligurt
Post by ligurt »
CMSMJ1 wrote: Sun Dec 09, 2018 3:49 pm Have a look on the fiche?
I have no fiche. Any idea where I can find one? The CMSNL fiche on the 1996 model from which the rim seems to come from have the f6 page missed, and couse of fat joke it's the one related to the front rim...
the fiches are on this site :)
http://www.400greybike.com/docs.htm
The bearing is a 6022 - so get one from any bearing supplier. double sealed is 6022RS (or something - it is the numbers that denote the fitment)
ligurt
Post by ligurt »
CMSMJ1 wrote: Sun Dec 09, 2018 7:17 pm the fiches are on this site :)
Do you think any supplier can manage that bearing codes? That is to say in the UK as well as here in northern italy? I'll take in account thanks. But what about oem part number?
Faxe400
Bike owned: VFR400RH, VF1000RG
Post by Faxe400 »
I would recommend using SKF or FAG bearing.
Yes, these numbers are unique for size, everyone uses the same. 6022 has 11 cm axle, needs a 17 cm hole in the Wheel and 2,8 cm thick -> I assume there is a typo!!!
Some extra characters indicate, if you have none sealed, double sealed (plastic or metall) ....
If you have the old bearing just measure those 3 values and you can search to get the number. I did this for my two bikes (wheels & swingarm) and bought bearing and shaft seals via eBay.
ligurt wrote: Sun Dec 09, 2018 10:20 pm
Of course - that is the "code" - it'll be the same wherever you are for ordering it. If you have the wheel with bearing in it, you might see the code stamped on it.
To add - you mention a 1996 bike for the wheel? Which bike?
ligurt
Post by ligurt »
CMSMJ1 wrote: Mon Dec 10, 2018 11:33 am
Great help, by the way your avatar is mind disturbing...
ligurt
Post by ligurt »
I don't know exactely. The wheel is the front Magtek 3.5x17.... so i desume it's from a 1996 rs250 or so. If any of you have more detailled informations they are over welcome
