Brake Caliper Help
sharkie
Bike owned: RVF400
Brake Caliper Help
Post by sharkie »
Can anyone tell me if the bolt that is holding the pads in usually looks like this?
https://imgur.com/a/niTxYPd
I can't seem to unscrew it without stripping the head so my only other option would be to soak it in WD40 for a while?
Any help would be appreciated thanks.
Bike owned: VFR400
Re: Brake Caliper Help
Post by magg »
Picture is lock nut cap. There is an allen key head underneath. I just used whatever method works (a punch and hammer) to remove it and did not bother to replace it. You will most likely find the pin is also difficult to remove. I also had to replace a pin, as the head was damaged trying to get it out. I now regularly remove and grease them to ensure easy removal in the future.
sharkie
Bike owned: RVF400
Post by sharkie »
Thanks... Will have to drill it out when I can get access to a drill I think. Can't punch it with what I have or grab it with pliers. Need to see what condition the pistons are in too... hoping they're okay.
Faxe400
Bike owned: VFR400RH, VF1000RG
Post by Faxe400 »
I was in trouble with that allen key had. I drilled out very little and pressed im a Torx Bit. There you could apply enough force to loosen the screw.
My Suggestion would be: try it with oil. If you drill a hole put oil inside (to work on both sides. Try to press in an Torx to have more force.
I press my thumbs for the srew underneath! You may buy cheap M10x1 srew tap from China to rework the screw thread ;) When assembling use some copper paste to prevent this happen again.
Axel
