Oil cooler and pipes.
freeserve
- Bike owned: vfr400 nc30
Quick one,
Are the oil cooler pipes from the earlier bikes such as the NC24 different to the ones the NC30 uk spec? Same goes for the oil cooler.
Thank you.
Sent from my SM-G950F using Tapatalk
Thank you.
- RickOliver
Re: Oil cooler and pipes.
Cooler is the same, pipework different - I can supply custom adaptors to fit off the shelf flexi oil pipes to the NC24/UKNC30 engines.
Details here - https://www.vfrdiscussion.com/index.php ... nt-option/
Rick
Rick
Dynamohum
Regarding the cooler the rc36 one looks closer to the uk spec nc30 cooler with the central single mount only difference i can see is pipe flanges bolt through the housing .
Just ordered one from ebay to compare will let you know result.
