My NC30 refuse to start
Maquesime11
One Hit Wonder
Post by Maquesime11 »
Hi guys,
I need your help and knowledge ...
I have a NC30 how works perfectly but this morning, "She" refused to start ... and after few try I noticed that I have no ignition from my spark ... so I tried 1, 2, 3 ... but the four one are not working ...
My guess is, the problem is coming from ignition unit ... ! not from sparks, I mean strange that in one day the four spark dies ... !
I hope my english is correct enought :?
Thanks in advance
cheers
Max
Bike owned: VFR400
Re: My NC30 refuse to start
Post by magg »
If you have three sparks then the ignition control unit is not at fault. If you have fuel then an engine with three sparks should run but not like a four. Think your spark test might be suspect. Do you have fuel flow from the tank.
