using a nc24 CDI on a nc21, help needed
bay031
- One Hit Wonder
Good day all,
I am a new member and not sure if this question has been raised before,
i recently bought a Honda VFR NC21 which i got for a steal due to no spark, i suspect the CDI unit went bad.
Upon inspection i noticed there is currently a NC24 CDI unit in the bike.
Due to the rarity of NC21 units in South African and the NC24 units being common my question is can i use a NC24 unit on my NC21?
From what i have observed the major difference is the 2 pin cam sensor plug not being present on the NC24 CDI unit.
TIA
TIA
- Bike owned: VFR400
Re: using a nc24 CDI on a nc21, help needed
It has the NC24 unit plugged-in and there is no spark?
From the info I have the NC24 ignition unit may function with an NC21 by simply by ignoring the cam sensor, although wiring setup my need rearrangement.
The P/N for the crank trigger mechanical parts appear to be the same for NC21/24/30 models.
Or perhaps someone on this forum has an NC21 ignition unit for sale.
decngb
- Bike owned: NC21, NC24, NC30, VFR800, MC19
NC21 CDIs are available on eBay. Here's one in the UK for 25 British Pounds that looks like it will ship just about anywhere.
https://www.ebay.com/itm/HONDA-VFR400-V ... Swpblbr1~D
I would be worried that someone rearranged the wiring. I just compared the wiring diagrams for the two bikes and noticed that the wire colors are mostly different. That makes me wonder about pin position as well.
You may have already done it, but I would check all the easy things first - wiring to kill switch, neutral switch and clutch switch. On my NC21, the problem was a broken wire in the kill switch circuit. On the NC24, it looks like the problem was a loose electrical connector.
