Couple of questions
nc30 duck
Couple of questions
Post by nc30 duck »
Hello all, realise I don’t post often, so apologise for popping up looking for help!
I have an nc30 r3n with twin stack Tyga system. I rejetted (120/122 I think) and replaced needles as per recommendation from rick Oliver. But after a dyno run to investigate poor response at 6-7k rpm it seems the bike is rich across the range but very rich low down.
Question is related to the cdi mod and what it actually changes!? I can see how to do it, but don’t understand what actually changes.
Cheers,
Matt
RoninZX-10R
Bike owned: NC35 racebike, ZX10R roadbike
Re: Couple of questions
Post by RoninZX-10R »
If you're referring to the 2.2K ohm resister that's installed in the orange/blue wire, it's used when the speedo has been removed for race bikes. If the resister isn't installed the ignition control unit restricts the amount of revs the engine can get to (I can't remember but I think it may stop once it gets to approx. 8,000rpm???).
Bike owned: VFR400
Post by magg »
As RoninZX-10R says Ignition mod allows full engine revs if the speedo is removed, otherwise mis-fire occurs at approx. 5000 rpm. Would suggest you just rejet to suit the engine's current mixture requirements. Any changes to exhaust/fuel system can have an effect for better or worse.
yep yep.. get it jetted to suit, the igniton box "mod" just cuts the speeo restriction as been already mentioned, doesnt do anything else.. you dont even need that resistor either you can just join the wires toegher.
