Splitting crankcases
- bikemonkey
So I need to replace my gearbox.
Once I've got the engine out of the frame am I right in thinking that I need to remove the following before splitting the cases?
Clutch cover
Generator cover
Sump cover
Gear selector cover
Water pump
Generator
Clutch
Primary drive gear
Front sprocket
Oil pump
OIl filter
Anything I've missed?
Clutch cover
Generator cover
Sump cover
Gear selector cover
Water pump
Generator
Clutch
Primary drive gear
Front sprocket
Oil pump
OIl filter
- Tim400GB
Re: Splitting crankcases
The rear head will need to come off
