nc35 project, help needed please
branc35
Hi
Just got an nc35 project bike , few issues, fork damper adjusters are siezed and fork seals are leaking, the preload adjuster on right fork doesnt screw down to remove circlip, just spins but can be pushed down but middle part moves down with it.
Indicators dont work, there is a datatool alarm fitted which flashes them, have checked switch and its fine and also have power going to the relay, I have tried another relay but still nothing.
- Bike owned: VFR400
Re: nc35 project, help needed please
LED indicators?
branc35
Think they are
LED indicators do not load the flasher relay sufficiently. You can add resistors or change the relay type. The alarm probably does not care what type of indicators are fitted.
branc35
thats great thanke ill try some different ones
branc35
Well you were spot on, tried on a normal indicator and they work, had some standard ones ordered anyway as I dont like the look of the ones on it.
Thanks for the help
Thanks for the help
The "middle" part of the adjuster can be screwed up and down independent of the preload adjuster. You have haynes manual, not a bible but has the basics right most of the time.
branc35
thanks got them apart today, threads on alloy part damaged and were not attached to the cap
