NC24 - progressive front suspension springs
radarro
- Bike owned: NC24 Rothmans
Hi,
Is anyone awared of progressive front suspension springs I could put into NC24 forks?
Googling for OEM part 51401ML0721 does not bring me any closer.
Could I use any other 80's Jap bike springs instead?
Is it possible that shop specialized in motorbike springs could find substitute based on dimensions of original springs?
BTW - anyone knows original spring size for NC24?
I'm getting ready to rebuild front suspension completely and need to build solid background before attempting.
On the other hand I think that even new original springs would do the job instead of 30 years old ones I use now...
Re: NC24 - progressive front suspension springs
You can get springs custom made for your weight and requirements and budget from most suspension specialists.
Rick O used to do progressiev springs for NC30, not sure if he has for nc24, might be worht lookin him out.
Faxe400
- Bike owned: VFR400RH, VF1000RG
You could start by measuring the spring free length to determine if they have reached the service limit. RG/ZG 371.4mm and RH/RJ/ZH 388.9mm according to the Haynes manual.
Suzuki416
Fairly sure that Hagon make some...
radarro
Thanks for feedback. Both Wirth and Hagon do not have NC24 listed on website, but will ask directly.
@magg - so far didn't know L and R springs differ and have different service limit. I based on CMSNL fiche's where both springs are identical (no 2 in link)
https://www.cmsnl.com/honda-vfr400r-198 ... x0KRYouDcs
But i'll give a check once forks dismantled.
Listing is different models, I am not familiar withe all VFR400 model types so gave you Haynes data for all models. Would expect from data, that springs are pairs of the same length.
Suzuki416
Here try a couple of links currently on sale on EBAY.
Wirth Springs
https://www.ebay.co.uk/itm/Gabelfeder-S ... SweM1aS-R-
HyperPro Springs
https://www.ebay.co.uk/itm/Hyperpro-Pro ... SwcfdbFs37
Wirth Springs
HyperPro Springs
RG/ZG is early NC21 and first naked NC21magg wrote: Sun Jun 10, 2018 1:38 pm Listing is different models, I am not familiar withe all VFR400 model types so gave you Haynes data for all models. Would expect from data, that springs are pairs of the same length.
RH/RJ/ZH is NC24 and later Naked NC21.
