Vfr 400 possible fuel starvation
Jaq213
Hi all,
My vfr 400 has started to give what I think is fuel starvation at 5500rpm. Just backs off. Idles fine and goes fine till that threshold . Any ideas?
- gavins
- Bike owned: NC30, ER6f, K5 750
Re: Vfr 400 possible fuel starvation
Will it just not rev past 5500ish at any time, i.e in neutral as well? Assuming an NC30 and assuming the speed restriction hasn't already been bypassed, check that the 3 pin connector from the back of the speedo is connected properly. If this is disconnected altogether the bike just won't rev past 5k from memory.
^^ what he said :)
Welcome to the site.
Have a search for 5500rpm or 5.5k and you will find oodles of data - the bottom line is that if the bike CDI cannot "see" the speedo then it cuts 2 cyls.
Easy fix and we've all been there!
Jaq213
Thanks for the reply. I'll check that out after work and let you know.
Jaq213
Hi guys, checked all connections but problem persists.
- Bike owned: VFR400
The detector electronics in the speedo could be faulty. As already suggested, disconnect the 3 pin connector from the speedo and apply the bypass to the loom side. The document library on the home page has instructions.
as magg has said... remove the speedo sensor plug and jumper the wire.
Jaq213
Thanks guys. Followed instructions and all sorted. Thank you very much.
