NC30 Race Motor rebuild
boyracer34
Post by boyracer34 »
Hi folks, apologies if I am repeating post info from elsewhere.
Did a big end on race motor, rebuild time. Ouch.
Q1: can failed VFR crank be repaired back to spec at all?
Q2: Parts Suppliers recommendations (Im in Oz) for:
Pistons , Stock and /or oversize
Shells
Gaskets kits
other motor component internals and externals
Any other must do jobs whilst motor is apart?
TIA folks.
Re: NC30 Race Motor rebuild
Ouch indeed :)
Get your monies and credit facility flexed and get a hold of Mike Norman and his boys at G-force racing - mngforce dot something will get you their website. As far as I am aware, they are the most reliable contact for shells and these odds and sods.
Good luck
Bike owned: VFR400
Post by magg »
Honda does not produce oversize engine bearings, although they are available on ebay etc. from China. Is the crank damaged or just the bearing.
Yakama
Post by Yakama »
Mike Norman does oversized bearings now
Bike owned: VFR400
Post by magg »
Mike Norman has bearing sizes for Honda production tolerance sizing. Crankshafts with damage will not be within Honda production tolerance and will need oversize bearings, provided repair is possible/practical/desirable. Hence my question as to whether it is a simple bearing failure or a damaged crankshaft.
gavins
Bike owned: NC30, ER6f, K5 750
Post by gavins »
As Yakama already said, Mike Norman is supplying oversize bearings as well as direct replacements for the Honda ones. http://mngforce.typepad.com/nc450vdev/2 ... rings.html
Bike owned: VFR400
Post by magg »
I think you will find that Mike Norman bearings sizes match the Honda production tolerance sizes, not the oversize required for a crankshaft that has been ground oversize to repair a damaged journal.
gavins
Post by gavins »
From Mikes website:
Also, for special circumstances, I have created some extra-thick Bearings. These will be used primarily for crankshafts that are undersized. This can occur if the crankshaft has been polished several times. Also, in the event of a mild bearing seizure, there may be an opportunity to polish it out and run thicker bearings.
Description Bearing Thickness G-Force Part No. Price/Shell Special Notes
Bearing, Conn-Rod, BLU 1.506-1.510 132P9S-NCV-220 $20.80 These are a stronger overlay for Racing
Bearing, Conn-Rod, BLK 1.502-1.506 132P9S-NCV-230 $20.80 These are a stronger overlay for Racing
Bearing, Main, Outer, BLU 1.506-1.510 13310-NCV-120 $23.50
Bearing, Main, Outer, BLK 1.502-1.506 13310-NCV-130 $23.50
Bearing, Main, Inner, BLU 1.506-1.510 13320-NCV-210 $23.50
Bearing, Main, Inner, BLK 1.502-1.506 13320-NCV-220 $23.50
Bike owned: VFR400
Post by magg »
Polishing out a mild bearing seizure is not a journal regrind. Thus my original comment regarding the level of damage as Mike Norman's bearings are not suitable. The Chinese replacements are claimed to be 0.25, 0.50 and 0.75mm oversize but quality unknown and would require surface hardening.
boyracer34
Thanks all, gathering good info, yeh the MasterCard gonna hurt.
