Carb rebuild
- Bike owned: Blackbird, CBR600F3, NC30, VFR
Carb rebuild
Anybody recommend someone or a firm who can rebuild a set of carbs for my 92 NC30? Time to start rebuild/resto of mine. Rebuilding carbs is something not in my skill set!
Re: Carb rebuild
Where are you located? Scottie Ducati and I just used Mike Nixon http://www.motorcycleproject.com/
The carbs turned out GREAT.
- NGneer
Re: Carb rebuild
Cheers lads, im in Worcester UK so ill get hold of gfracing. What does he charge for a rebuild?
Re: Carb rebuild
Cheers, good luck!adeyren wrote: Fri Mar 09, 2018 6:35 pm Cheers lads, im in Worcester UK so ill get hold of gfracing. What does he charge for a rebuild?
- NGneer
Re: Carb rebuild
It is a bit of a sliding scale. Depends if you are exchanging your old carbs and what (if any) trick components you want included.
Give Graeme a ring or drop him an e-mail
