Page 1 of 2
NC35/30 rear sprocket
Posted: Tue Jan 23, 2018 11:48 pm
by saltysealion
I know the stock teeth count is different but are the dimensions/fitting the same?
IE, can I order a NC30 525 sprocket and slap it onto a NC35?
Some webpages just don't list a NC35, but they do for the NC30..
Re: NC35/30 rear sprocket
Posted: Wed Jan 24, 2018 8:49 am
by SPOONDIDDLY
Yes, they are the same
Posted: Thu Jan 25, 2018 10:44 pm
by hunter
Yep same.
Posted: Sun Jan 28, 2018 1:01 pm
by saltysealion
Thanks, helps a lot with some sites that list VRF but not RVF.
I can easily request 38Ting to stay stock :)
Posted: Sat Feb 03, 2018 2:40 pm
by JZH
Same as RC30, innit? The sprocket carriers are the same, bar the colour.
Ciao,
Posted: Thu May 10, 2018 11:31 pm
by RickOliver
Yes, the NC30, NC35 & RC30 all use the same rear sprocket - take note that if you are fitting a 525 sprocket the machined recess faces inwards, not outwards i.e. unlike most bikes the sprocket is offset towards the wheel, not away...
Rick
Posted: Sun May 13, 2018 2:19 pm
by saltysealion
Hi Rick,
I'm a little confused.
One side is flush flat, the otherside has a ring protruding. Are you saying that the flush side should be on the outside?
Posted: Tue May 15, 2018 10:40 am
by NGneer
saltysealion wrote: Sun May 13, 2018 2:19 pm Hi Rick,
Saltysealion - Yup that is exactly what he is saying Flat side of the sprocket facing outwards - ie to the left as you are sat on the bike :grin:
Now you know this you will see loads fitted the wrong way around, but obviously it doesn't seem to cause any great issues.
:rocks:
Posted: Tue May 15, 2018 3:49 pm
by saltysealion
WOW, thank you so much. I was about to install it on the wrong way!
Posted: Wed May 16, 2018 8:34 am
by NGneer
saltysealion wrote: Tue May 15, 2018 3:49 pm WOW, thank you so much. I was about to install it on the wrong way!
Easily done and instinctively you would think it should go the other way around.
Once you know you will see so many fitted the wrong way around but without any major issues that I am aware of, so can't be too much of an issue ;)
