Derestriction
thehappyshark
Derestriction
Hi guys,
I have what I think is a pretty standard import 3TJ, now it has a kmph to mph converter so I assume the 180kph restriction has been removed by default. I have read that there is a 12,500rpm rev limiter too. Is there a way to remove this without buying a mad max box or a derestricted CDI?
Re: Derestriction
This old chestnut
If you have a kmh to mph converter fitted and nothing else done your sorted, but check the wiring behind the Speedo is still connected.
The bike should rev to 14500 rpm
thehappyshark
Re: Derestriction
Thanks will find out tomorrow when she goes up on the dyno
