where are the carb vacumn pipes?
geoff916
Bike owned: CBR 1100 XX, CBR 400 RR CBR
Post by geoff916 »
Hi
I need to balance my carbs, I only have a two gauge set up but I do need to know where they connect to ?
looked on the net, lots of videos showing this being done, but where the h**l do I connect the vacuum gauges to ?
Thanks in advance guys
Geoff916
dunkenb
Regular Member
Bike owned: Cbr400rr nc29 type8 NSR250
Re: where are the carb vacumn pipes?
Post by dunkenb »
Take the carbs off and you see them on the engine under the intake stubs.
CB1pod70
Post by CB1pod70 »
There are 4 screws in the inlet stubs cast into the cylinder head below the carb rubbers. From memory they are M5 thread so you will need the adapters to give the balancer pipes something to connect to. you should be able to see the ones for the outer cylinders without removing the tank etc. but will obviously need to take the tank off to gain access to the balancing screws on the carb linkages
dunkenb
Regular Member
Post by dunkenb »
If it's a 29 the adapters are already fitted with rubber boots over the ends
